urgent help with 8800 gts
trance247
363
I was using 8800 gts and infocus projector via hdtv out and component cable, everythign worked fine for a while. Then I had a nasty crash, booted back into windows and had to mess with settings to get everythign working again. Now it does display everything, but colors are messed up. Everythig is in blue and green. Any ideas?
Captante
30,354
10,880
The first thing to try is un-installing & re-installing the video driver because its sounds like somthing got corrupted when your PC crashed. It could also be a problem with the RGB cable or the video card itself, but as long as the cables are all still tightly connected do the driver before you worry about hardware.
