Urgent Help Needed
It is getting close to my bed time and I can't get this bloody thing to work. And when it takes 30 minutes to encode a file, time sure flies. I need to get this thing done fast.
I need to shrink a 5gb file (which is only 25 minutes of footage) down into a reasonable size so that I can burn it onto a VCD.
I've already tried DiVX through Dr. DiVX and the audio is off sync with the video. Is there a built in codec I should use within Adobe Premiere?
I can't sacrifice too much quality with the compression, but obviously I have no way of transporting a 5gb file.
Any help and advice is greatly appreciated.
Edit: I need help ASAP, if you could, contact me on AIM: MrCodeDude87
