Turbonium
I'm installing a new P4 CPU with a Zalman 7000AlCu, and I'm having some trouble.
It says I have to screw in each side progressively until the clip is touching the clip supports on both sides.
On one side, it's almost touching, but on the other, it's like, half a cm or so (a bit less maybe) off, and the clip support can still move about, etc. The screw refuses to go further. It's pretty clumsy and I'm worried that I'm doing something very wrong...
UPDATE: Ok the one clip that is refusing to get screwed in is not threaded... it's only partially threaded (like drilled with the wavy pattern thing...).
Should I force the screw in anyhow? This is so annoying.
