URGENT!!! Help!!! Installing hsf, tiny bit of cpu isnt covered by Heatsink at one spot, ok?
RyanB18
378
I am installing the Heatsink/fan on my new mboard. Is it ok of a few milimeters of cpu are sticking out the site of the heatsink? Urgent!
Swanny
7,456
You're saying that part of the ceramic is sticking out? That's ok, and it would be really hard for a part of the core to be sticking out. However, if it doesn't cover the CPU all the way, it's probably a pretty cruddy HS. You will probably want to get a new one, like a TaiSol CGK 760092. What CPU are you using?
