Urgent computer (building) help
timosyy
1,822
So I was building a computer for a friend ... put everything together, plug it all in, start it up real quick w/no moniter or anything connected & comp wide open (just to check) and ... nothing.
No fans running- its like it wasnt even plugged in. PSU fan didn't even budge. Nothing heating up, no whining, um ... nada. I think theres a faint electrical buzz like maybe theres a surge of something but nothing is happening. Sometimes the CPU fan will nudge like half a centimeter when I hit the power button.... but it did that even when I had turned the switch on the back off (which made me go wtf).
I thought maybe I had the power button connector backwards but that wasn't it... Then I thought maybe the 4-pin power connecter was in the wrong way (motherboard has a 24 pin ATX connector, 20 in one spot and the 4 next to it), but when I turned that around still nothing.
I'm thinking its either a dead PSU (which would suck but ok), or I messed up royally (which would NOT be good).
Thoughts?
Edit: Antec Sonata II & Asrock 939 mobo
Goosemaster
48,775
:laugh:
either psu isn't plugged in correctly, bad psu, bad board, or bad board becasue of psu....or the board is shorted out due to contact with the case...
drinkmorejava
3,567
7
I'm guessing PSU.
the buzz is most likely from an inductor coil in the PSU which is either broken or is getting more power through it that it was designed for.
S
SlitheryDee
Dead PSUs can do that.
also
Originally posted by: keeleysam
There's a short.
Check to make sure you don't have any misplaced standoffs/loose screws etc. behind the motherboard.
So step 1 is pull the MB and make sure nothing's back there shorting it.
Step 2 is find another PSU and test the system with it.
Step 3 is report back if that doesn't work.
timosyy
1,822
Not sure how it could be a short or how I'd go about "fixing" that... no way the motherboard could be touching the case (besides the supports...)
Um... advice?
How weird is it that even the fan in the PSU doesnt turn on? o_O
Edit: I would do some serious diagnostics with my computer (only source of swappable parts I can get to atm but thats ~10 miles away and its nearly 1am...) Um..
Gonna take out mobo and check for loose screws.
everman
11,288
wrong forums but quickest response ftw?
Indeed, but coherent, or helpful?
What you need is a piece of pie, a hamster, piece of cheese, and a plunger. You know the rest... :eek:
S
SlitheryDee
Um... advice?
Make absolutely sure that every standoff ("support") lines up with a hole in the MB and that there are no extra ones that don't line up. Loose screws are generally unlikely but misplacing standoffs is pretty common.
Edit: I must be in a GH mood and not realize it...
Geekbabe
Moderator Emeritus<br>Elite Member
Oct 16, 1999
32,234
2,554
www.theshoppinqueen.com
Um... advice?
test the MB outside of the case,set it up on a board with cpu, ram, video, keyboad, plug in the PS connector and see what you've got. if it won't boot, recheck that your cpu,ram etc are seated correctly etc.
Amplifier
Banned
Dec 25, 2004
3,143
Putting a 20pin PSU into a 24pin motherboard wrong can be instant death for a motherboard's chipset. Pray it's the PSU
timosyy
1,822
What kind've power supply?
The bundled 450W Antec Smartpower
I'm guessing improper MB contact with the case...happened to me many times.
Not as far as I can tell (just took the mobo out and re-checked)
CPU, RAM, is seated correctly. Testing the MB outside the case will have to wait for tomorrow but I hate leaving my friend with a half-open non-functional case w/o some conclusion before leaving tonight.
There are no extra standoffs/supports- they all match up to a hole on the motherboard- every single one. I made doubly sure of it since it was a friend's ... normally on mine I just connect the 4 corners & a few in the middle or something, but this one has all the supports matching up and none missing/no extra.
It was a 24 pin PSU into a 24 pin motherboard.
timosyy
1,822
Originally posted by: bleeb
PWNED. Try using another power supply and see if that works.
The only PSU I could try that with is my home computer's ... which is a 350W and I don't think could handle the hardware plugged into his mobo. I could do it the other way around though... Take his PSU home and plug it into my comp. That would have to wait until tomorrow though and I hate to leave a friend hanging like that.
Dead comp, half open, parts strewn across the room, boxes everywhere, 2am, etc...
So, thoughts on culprit? PSU would be the easy way out but it seems I'd rather blame a mistake on my part.
timosyy
1,822
Damnit I really have to go home... bump & i'll check when i'm home I guess -_-
Feel like crap.
