Well, short of removing the door panel to disengage the motor, there is not much you can do about it that I am aware of. You might be able to pull the fuse for the window motors, and if the motor is getting no power it might make it easier to move the window up by hand, but I tend to doubt that, as the window motors typically only get power when the ignition is on.
