Wanted to know how do you keep those UPS in tip top shape?
I have 3 units (2 APC and 1 Belkin), and so far only one still works properly.
They are about 5 years old now. The one APC seems to need a battery replacement, which from what I heard is kinda expected since most people say those battery only last about 3 to 5 years anyhow.
However the one Belkin just borked out after 2 years. During all the time I used it, we almost never had any power outtages, however anything plugged into the "battery backup" plug will shut down after a few minutes. So most likely it just bites the dust on me.
In any case I'm currently looking to get another UPS for my tower. The PSU is 750 Watt, and I got an LCD plugged into it. From what I gather around a 1200 VA ups should work just fine, am I correct on this?
Also how do you maintain UPS in good order? Do their battery have to be cycled (fully charged and drained) every so often to ensure good working order (like other rechargeables)?
Thanks for all the help ... by the way I live in a condo with the power plugs all wired to 15 amp circuit breakers, will this work fine with the said 1200 VA UPS ? I've read that some big power UPS need 18 amp circuits and stuff.
PS: My old ones were 550 and 350 VA units and both were used with my old PC with only 300 Watt PSU.
