- Jun 30, 2004
- 16,709
- 2,081
- 126
I should try and make the long story short.
A certain established battery reseller also offers a wide variety of "refurbished" UPSes, and I decided to go that route, ordering one of them. They made a shipping mistake; charged me for the one; and sent me two. I was happy to inform them of their error so they could take corrective action for the future, and offered to send back the second unit if they would send adhesive shipping labels pre-paid. But since shipping charges are $57 each way, I'm pretty sure that I'll end up keeping the second unit. Both of them were the same APC SMT1000 model. So -- lucky me. I got two for half the price of one. The link below shows the brand-new unit offered at the Egg:
APC SMT1000
Some UPSes offer three-prong output ports which are merely surge-suppressed as opposed to those behind the battery. These units apparently don't have "surge-suppression-only" ports.
Usually, you get the advisory in the install and operation guides to avoid connecting a printer to the UPS (unless it has surge-suppression-only ports).
Because of limited wall-sockets, I'm toying with the idea of connecting a printer anyway. The printer's maximum power draw is ~300W, and idle draw is 8W. Under the less-likely scenario that a power outage will cause the unit to switch when as much as 500W are being drawn from the UPS, shutdown would still occur within 3 minutes.
Should I or shouldn't I -- use the SMT1000 to power the printer in addition to the PC and minor peripherals? What do you think? Comments?
APC SMT1000
