UPS communication problems in Win2k
Escalade
512
I have a Back-UPS Pro 1000VA connected to my system, I?m running Win-2k, when the power goes out the system is set to give warning after 30-seconds, then shutdown after 5 minutes. When I pull the plug on the UPS I don?t get any messages (I know how this works, because I have another Win-2k system with the same UPS and that system works fine!) The problem is there is no communications between the UPS and Win-2k.
I?ve tried different connecting cables, verified port operation with other devices, even switched the UPS with the old UPS unit on a different system and have narrowed the problem down to within Win-2k.
The problem is I can?t find a way in Win-2k to uninstall just the UPS software and reinstall it... do I have to do a complete Win-2k reinstall just to fix this problem? Any ideas?
TIA
jkoXP
Banned
Dec 14, 2001
709
thats strange, is it serial or usb connection? and also, are you using powerchute? try getting the latest powerchure personal edtion
Escalade
512
<< thats strange, is it serial or usb connection? >>
Serial. COM1 to be exact. :)
<< are you using powerchute? try getting the latest powerchure personal edtion >>
No. I use the built-in Win-2k UPS software... works fine on my other system.
Escalade
512
It?s strange that there is no UPS listed in ?device manager? or in ?add/remove programs? - even on the system where the UPS and software are working perfectly! Looks like I might have to re-install Win-2k to get this working.
Escalade
512
I guess no one ever encountered this situation? Aren?t I lucky! ;)
Well, here?s what I did... in case someone searches the archives?
There seems to be no way to just uninstall/reinstall the UPS portion of Win-2k, so I did a complete reinstalled of Win-2k, SP2, IE5.5, and all the security roll-ups, and it cured whatever problem(s) was causing the built-in APC software not to communicate with the UPS unit.
