Ups and Downs of inversion thearapy
coomarlin
796
After suffering from mild backpain for the last 4-5 years I came across an inversion table at Sams Club the other day. I remember seeing them when I was a kid in the 80's and always thought it would be neat to try them. I searched the internet for information and it appears they are making a comeback. I read as much information as I could over the last few weeks and can't make up my mind weather to try one. The most obvious benefit is that by being inverted gravity acts on your body and decompresses your spine. It takes all of the compression weight off your spine allowing the space between your vertibrate to relax therefore allowing more blood to flow into the area. Sounds like it would feel really good to me.
There seems to be 2 camps in the debate on the benefits and drawbacks of inversion thearapy. The opponents to inversion therepy say that by hanging upside down you are allowing blood to rush to your head and that your veins aren't neccessarily able to return the same amount of blood to your heart therefore there is a possibilty of too much pressure building up in your head. If thats the case theoretically you could suffer a brain anuriysm (sp?). I've also heard people say that your eyeball would be subjected to too much pressure.
Supporters of invertion thearapy say that there has never been a documented case of someone having a stroke or anurisym from using an inversion table. Considering that you are only upside down for 1-2 minutes at a time there appears to be almost no risk involved.
I was wondering if any of you fellow A-techers have ever tried an inversion table and what are your thoughts about them.
Alchemist99
1,172
I haven't tried it but I like the idea, I've always wanted to get those boots that hang you by the ankles but then I might drop on my head and break my neck. I think in theory it makes sense that it would work. as far as the aneurysm goes if it's you time its your time.
pics?
coomarlin
796
pics?
Your probably right. I went to Sams website and they didn't have it listed on their site. But here is a site on the net that sells inversion tables similar to what sams Club had. By the way, the table at Sams club was $149.99. Supports up to 250 pounds.
