UPS after water damage
ochadd
Sprinkler system went off in the office and a dozen UPS got flooded. I've dried them out and some are working again. I'm leaning towards tossing them anyways just in case. Is it a "good" idea to reuse a UPS after having been flooded out?
Some people around here don't seem to think it matters.
Water can cause a short, permanent damage that effects whether it works, and works properly. Be sure to test their functionality powering something of no value when you turn the AC circuit off to see if it handles this test. Obviously the safer course of action is to accept the loss, file the insurance claim if applicable, but it is probable that if one passes a load test it will be fine. No guarantees.
Most normal water isn't all that conductive, but any sediment left from drying could cause problems. If they can be gotten to before they dry, then a rinse out or two with distilled water followed by an alcohol rinse to help get rid of any remaining water and they should work OK.
. IDK what would happen if water got into the gelled electrolyte batteries thru a vent or something. I wouldn't think other components would allow water in unless it got pretty deep to develop some pressure. Probably for personal use I'd try to rehab them with new battery(ies), etc., but for corporate use, I'd have them replaced if the insurance covered such. In future, locate your UPSes up off the floor (e.g. on plastic shelving) so they won't be susceptible to minor flooding. I'd also call the UPS mfr. to see what they recommend to do in the case of minor flooding - of course they'd want you to buy more of their UPSes so that has to be taken into conderation in evaluating their answer. In any case, getting the flood water out of them and rinsing before allowing the flood water to dry inside them would go a long way toward any possible recovery of some of them.
.bh.
APC got back to me and said it would be alright to use them. My biggest concern isn't that the power would drop as they aren't on the most critical machines. Fire/sparks is what keeps me up. Going to be trying them out. Thanks for the input.
