Upgrading ReplayTV with larger Hard Drive ...
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
I am seriously considering upgrading my ReplayTV 3060 with a larger drive to increase it's recording capacity from 30 hours to something much larger.
I'll probably get a Maxtor or WD hard drive through a Hot Deal.
What's the best GB size (40/60/80/100/120) to get and which speed 5400 or 7200RPM?
Thanks.
Ameesh
23,686
get a maxtor that is 5400 rpm
size is up to you, 1 gb == 1 hour of recording at extended
i think for high quality its 3:1
-Ameesh
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
Thanks Ameesh!
There are several 5400 deals out there, is there any particular reason why I want 5400 instead of 7200?
Doggiedog
12,780
My friend got a 120 hr one from a popular guy on ebay for about $20 more than the cost of the drive.
The guy said you should get a 5400 RPM version if you can because it emits less heat and is more quiet.
He said anything bigger than 120GB will probably not work.
Ameesh
23,686
Originally posted by: RossMAN
Thanks Ameesh!
they are reccomend because the heat generated by a 5400 is less then a 7200 and you dont gain any tangible benefit from getting a 7200.
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
Thanks for the info.
Would you mind asking your friend what this guy's eBay user id is?
It's a long shot but I might be able to get a Maxtor 80GB 5400 HD and CenDyne 32x CD-RW for around $80 from Staples after some fancy Hot Dealing, search Hot Deals forum for Maxtor.
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
Originally posted by: Ameesh
remeber you can also have 2 drives in there at once
I noticed that.
What are the benefits of a dual hard drive setup? I guess it would save me from selling or tossing out the original HD, if it isn't that much more difficult I guess I'd prefer a dual setup.
Thanks again for the info.
Doggiedog
12,780
PMed you the link.
Funny thing is, my friend offset some of the cost of new HDD by selling his old 20GB HDD on ebay as is and he got some ridiculously high amount for it.
I've got a 60HR RPTV and love it. Still on the borderline of whether to upgrade it or not.
thereds
7,886
PMed you the link.
Totally off topic (sorry Rossman) but how much will a WD 7200 80gigger go for on ebay? Any guesstimates?
Ameesh
23,686
I noticed that.
yeah, what are you gonna do with an old drive
its not more difficult you just need to get a 'Y' power cable connector.
PsychoAndy
10,735
I cant believe i'm saying this.
Ross, go to OD and get a maxtor 40 or 60 gig. use an OD $20 off of $50.
I KNOW i'm not supposed to tell you to spend money...but if you absolutely have to, I'm going to have you spend the least amount of it.
40% off is 40% off. $30-$40 for a new hard drive out the door IMHO is pretty damn good.
-PAB
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
Thanks PAB, I might get a 60GB the price is a lot cheaper than a 80/100/120 would be.
What are the major differences between the Maxtor and WD 5400's? I want something reliable, QUIET, low heat, and 100% compatible with a ReplayTV upgrade.
PsychoAndy
10,735
PMed you the link.
Thats my department. New or used? With packaging? Sealed?
-PAB
PsychoAndy
10,735
IMHO, Maxtor. I like my maxtor 20 gig OEM that came with my dell and I added a quantum 30 a little bit later.
IIRC, arent most HD builds compatible with replay TV?
-PAB
dolph
3,981
rossman -
i upgraded my old replay pvhs-1000 (panasonic's model) with 2 80 gb 5400 maxtors and a panaflo fan. not sure how it is now (i sold it some months ago), but i never heard back from the guy who bought it so i assume it's fine. i have heard that 7200 rpm drives run significantly faster than the 5400 rpm ones, without significant temperature difference (as long as you take off the ez-bake enclosure), though cooling solutions do exist.
my advice: get a couple of the wd 120 gb drives (hot deal here) or the 80 gb drives (the 7200 maxtors are fine), add a fan or go on ebay for a modified notebook cooling system (this dude is legit), and have fun! plus, upgrading it to a higher capacity increases the resale value of it if you want to trade up for a 4000 like i did (i managed to sell my upgraded 160 hour replay that had a total investment of $250 for $825, giving me the cash to get the 4040 when it first came out). you're gonna love it! if you need any help, pm me & i'll be glad to assist. gl!
Thegonagle
9,773
I just did my Tivo. Sadly, it was out of necessity, since the original HD was dying, causing skipping sound/video and random freezes and resets. I was originally planning to simply add a second drive to the first, 30 GB unit. I now have a 65+ hour Tivo from a 60 GB Maxtor D540X 5400 RPM drive. That's more storage than my computer!
(Now I've just got to resist the hot $100 deal 120 GB WD at Circuit City, because I still want more hours on my Tivo.)
Just be sure to print the instructions out on paper first, or have a second computer running, because you'll be using your computer to set up your drives for the upgrade (if the RPTV upgrade utilities are like the Tivo utilities, you'll boot from a CD or floppy into linux).
Good luck. :)
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
Garfang - I was looking at that 120GB for $99 also, looks very tempting esp since I'll probably visit CC B&M tonight to buy the FireWire card for $20 after rebate.
Your 65 hours capacity is that at the lowest quality?
Thegonagle
9,773
My bad! I just looked at my quality set-up screen again. It looks like this:
  • Best Quality (17 hrs, 35 min)
    High Quality (28 hrs, 20 min)
    Medium Quality (37 hrs, 26 min)
    Basic Quality (63 hrs, 7 min)
So 63 hours, not 65. :eek: I was getting sleepy last night when I finished up the project.
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
I would probably view my ReplayTV at medium or high quality if I were to add a larger HD.
Thegonagle
9,773
Yeah. I've set the default to medium quality now because it's so much better than basic (low) quality. If I upgraded to 180 hours (60 GB + 120 GB), I'd probably set it to high, good for 85 hours!
