- Dec 26, 2007
- 5
- 0
- 0
Ok, so my old comp took a dump, and its time to upgrade anyhow, so these are the new components Im thinking about:
ASUS Maximus Formula (X38) - I want to be able to upgrade to the new penryn/yorkfield eventually, so this looked like a good board
2GB ( I run XP, if I ever use vista, I will just double) Corsair Ballistix DDR2 1066 (PC2 8500)
E6850 Core 2 Duo (3.0GHZ) with 1333FSB
Here is my dilemma, and a problem for me. Can't decide between the 8800gt from EVGA, or the Radeon 3870.
The one thing is, with the 3870, I could do crossfire, but I would need a new PSU, if I don't already. I was thinking the evga 8800gt for their step up program, in case the new one comes out in 3 months, but if you guys don't think it will, then which should I go for? You think the 3870 will come closer to the 8800gt with some driver improvements?
Here is the real problem though, I have a 480w PSU, and I heard that would be enough, I only have 1 HD, and 2 DVD drives, one is a burner, but this was before PCI-Express, and the new board will have PCI-E 2.0. I heard something about needing 6 and 8 pin (6+2?) connectors, which I don't think my PSU has. Do I need to get a new one, or is there some sort of converter that can go from the old connectors to the new style ones? Please help me sirs, I need it bad, I am planning on ordering it this coming Monday, and I want to make sure I get everything I need.
Mainly used for gaming, not media or multitasking, I have a Mac for that (puts flamesuit on). I won't be overclocking it, thats why I am going with the E6850 (would it be worth waiting for the new E8500?? Something tells me not, and I need a computer by end of next week, but I would like to know).
The main thing is the power supply issue, I don't want to order this all and then find out I can't even hook it up to my PSU. If i were to go crossfire (assuming any of you think that is a wise decision) what kind of PSU would I need for that.
PS: I have 1 SATA 250GB HD, a DVD drive, and a DVD burner, and 2 case fans. Hopefully I gave you guys enough info, help would be much appreciated, thank you guys!!
