Upgrading in a few minutes...will I notice anything?
Goosemaster
48,775
Now:
2500+ barton @ 1.8ghz (stock)
1GB pc3200 DDR
X800xl @ 408/526
OS drive: 250GB Maxtor
then:
around 3900 3dmarks
then:
A64 3000+
1GB pc3200 DDR
X800xl @ 408/526
I realize that the main benefit will consist of FINALLY being able to play my HD files (in TS and in h.264:D) but I wanted to see what type of benefits I can get in gaming...
BigCoolJesus
Banned
Jun 22, 2005
1,687
gaming wont really be much different unless you OC the 3000+ (they can get up to 2.4GHz easily) or wait for 64bit games, which could take a long time
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
It will really depend on what resolution you're running at, what games, etc. If you were CPU limited before, you're going to see a big increase in performance, but if you were GPU limited in your settings before, the difference wont be huge.
Goosemaster
48,775
It is a 3000+ "newcastle" CPU and a SOLTEK SL-K8AN-RL mobo
It was not bought with overclocking in mind so I'll have to research it..wish me luck:(
Goosemaster
48,775
1600x1200 4x/16x in everything that has settings that high:D
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Hmmm... probably pretty GPU limited then... only one way to find out though ;)
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
From the looks of it my board doesn't overclock well AT ALL:(
Upgrading in a few minutes = ordering, or putting in the parts?
Goosemaster
48,775
Putting in parts. It used to be a video editing machine but it was overkill so I am shifting it to gaming/htpc use:D
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Good luck :thumbsup:
Nocturnal
18,927
I went from a 2500XP to a 3200+ Winchester and I did not notice that much of an increase in performance.
Goosemaster
48,775
Shadddddddddddddddddup:(
<---can't handle the truth:p
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
I also went from a 2500XP to a 3200+ winchester and noticed quite a performance increase.... of course I upgraded the ram, and videocard at the same time too ;)
w00t
5,545
ur wrong, you will see a difference in fps.
this is why your wrong:
the AMD64 processor can simataneously run 32bit apps. He doesnt have to oc it nor does He have to wait for 64bit games. There is already some such as farcry 64bit which, actually did worse in benchmarks.
Goosemaster
48,775
That is all I wanted to hear:cool:
Goosemaster
48,775
wow...the boost was great
3900 (around 4000) to 4900 (around 5000) in 3dmark 2005:D
Framerates are up in everygame...and I can now play h.264 1080p video flawlessly:Q
QuantumPion
6,010
I'm about to upgrade from a p4 2.8 ghz to a amd 4000+, also getting 2 gigs of ram from 1, and a raptor drive from 2 small raid 0 drives. I'm keeping my AGP 6800 gt though. How much of a performance increase should I be expecting?
