Naer Diamond Member Nov 28, 2013 3,435 181 106 Jul 1, 2016 #1 how much can i get away with spending for something. I noticed bad fps on some maps with the stock card when i bought this dell 8500 is this a good upgrade from amazon? EVGA GeForce GT 730 4GB DDR3 128bit Dual DVI mHDMI Graphics Cards 04G-P3-2739-KR
S SPBHM Diamond Member Sep 12, 2012 5,066 418 126 Jul 1, 2016 #2 http://www.evga.com/Products/Product.aspx?pn=04G-P3-2739-KR this card is horrible if the specs are right, 96 Cuda Cores and PCIE 2.0? that can only be the ancient Fermi based GPU from the GT 430 it's probably slower than your 7570 if your 7570 is the GDDR5 model you need to buy at least a 750 ti IMO or don't bother upgrading... but ideally you would look at better cards
