4K will be completely unusable on that system for anything other than Netflix or the like
Even for that won't work, as Netflix 4k requires Kaby Lake
My PSU only has a 6-pin power connection. The 470 cards listed are 8-pin.
Going for the Zotac 1050 (gives me a 5 year warranty too).
Kind of disappointed by this.. I know I can get an adapter but I guess this the universe telling me to stick to my budget and get the 1050 or 460.
Thank you very much everyone, I was definitely going for the rx 460 because of all gimping rumors and I am also AMD fan but I think I will get the 1050 instead after listening to everyone recommend it.
By the way, AMD has Frame Rate Target Control that helps reduce power consumption and heat while playing old games, does Nvidia have a similar feature? Googling only shows an software by EVGA called Precision X and a feature called 'Adaptive Sync'.
That doesn't surprise me at all. Pigs will fly before ASUS will honor a warranty.stuff of legends but failed within 3 months and the service center wouldn't replace it, it was an ASUS
OP has already made his decision. He bought 1050 2gb for $140 when 1050Ti 4GB was available for $175. Bad choice i would say.
