I have an Abit BE6 motherboard, installed latest BIOS, says it can support up to max P3 850. I was using a P3 450 Slot 1 for a long time and now upgraded and bought another Slot 1, P3 800(100mhz) CPU, swapped it in.
I tried default setting of Multiplier 8 X 100mhz and even user defined 8 X 100 with 2/3 agpclk/cpuclk and everything else default. Whenever I try to run a game or access a webpage with flash animations, its locks up with no error message, can't use reset button. My P3 450mhz never had any of these problems and a same slot 1 cpu upgrade is all i did....
Also tried formatting and reinstalling windows, no luck. =(
Other Stats in case they help: 128mb (pc100) + 128mb (pc133)
TNT 2 Ultra AGP card with 32mb ram
