Originally posted by: Bateluer
Anything you do now is going to be a stop gap measure to postpone the inevitable. Upgrading the video card will provide a nice boost though.
Just keep in mind that you have an antique CPU on an antique AGP motherboard. If you buy an AGP card now, then go to upgrade your CPU/Mobo in 6 months, you're going to have get new videocard too. Better to upgrade to an A64 3000/7800GT combo now.
Originally posted by: SuperTyphoon
They were right. a 6600gt is perfect for you.
Originally posted by: duragezic
Wow, I thought the consensus would be CPU. I think a 1.4ghz is much more outdated than a 9600 (you can overclock it probably). I have a 9800 Pro and I consider my 3200+ (when its stable enough) to be the bottleneck, but that could go either way I guess. So it would definitely cost more but I'd do CPU/RAM/MOBO (with pci-e) then 6 months down the road, pick up a now current gen video card for cheap.
Originally posted by: JASANITY
yeah, i only have 512mb of pc133 ram. will upgrading the ram be necessary if I get a 660gt?
Originally posted by: BenSkywalker
Your CPU is going to fall below minimum system requirements long before your video card. The Socket A SDR system level performance is holding back what your 1.4 is capable of, and that isn't too great to start with anyway. It is true that in games you can run perfectly fine at the lowest graphics settings a vid card will give you a larger improvement when you crank the details up, but that won't do you much good if the game won't run decently at any setting.
With that said- do you know what stepping TBird you have? There is a chance you may be able to push out a reasonable OC delaying the need to upgrade if you have one of the decent cores. It won't be a huge performance boost, but you seriously need a new platform which creates a bit of an issue for you.
Being on a SocketA SDR platform with an AGP graphics card you need to replace your whole d@mn system to do the kind of upgrade you are closing in on needing. It may be a good idea for you to start preparing for that now and saving your pennies away to replace your entire setup(mobo/CPU/RAM/vid card). You could go with an AGP based Socket754 solution but then you will find yourself looking at needing to replace your platform again the next time you upgrade(better to spend slightly more- get a superior platform and save yourself a bit down the line).
Originally posted by: selfbuilt
Give the guy a break ... he doesn't need to go to PCI-e right now, and a video card upgrade is not his best choice anyway.
Any video card update is going to be severly bottlenecked on his current system - basically, you will be able to turn the eye-candy on (AA/AF), but will still be limited to the same frame rates that he is currently "enjoying."
Don't believe me? Look at the numbers: Toms' VGA charts II. Although out of date, it shows the comparison for a Athlon 1Ghz/PC133 vs a XP2700+ for a 9500pro (similar enough to his 9600pro). Note that anything higher than a GeForce3 was fps-limited on all the benchmarks on the lower end system (which is pretty close to Jasanity's).
I'd recommend upgrading the cpu/ram/mobo and stick with the 9600pro for now (which is still quite playable, frankly). You could a cheap socket 754 system with a sempron chip and value ram and do extremely well for yourself. And high-end AGP cards are still around and easily available for future updates (even the current top of the line ATI X850XT PE for goodness' sakes!). Yeah, yeah, that may be it for AGP (or maybe not), but I don't see him needing a $700 super-high end card anytime soon.
P.S.: Jasanity, you might want to check out the CPU/overclocking forum here for more suggestions on system components..
