Hi, I have two questions about the same computer. The specs of this computer are:
Athlon XP 1700+
Asus A7V266-C KT266A Motherboard
512 Mb DDR Ram in two 256 MB modules (PC3200&PC2400)
MSI G4Ti 4400-TD 128 MB DDR
The person using this machine is currently working on a very large 3d file for modeling buildings. I'm not sure if the program being used is 3ds Max or 3d Studio Vis. I know both of these programs are used, but i'm not sure which one is being used for the large 3d drawing. Either way, these two programs are similar. The user of this machine has no problem working on smaller files, however this file is big because it is modeling an entire housing complex. It is when modeling these large designs that slowdowns begin to occur. So, my first question is: Aside from a professional graphics cards, what is the best upgrade for this computer that will speed things up? I've been thinking the RAM is causing the slowdowns, but I'm not sure. If you guys think the only thing that will speed the computer up now is a professional graphics cards, please tell me that also. Thanks!
Now here's my second question. When they actively editing their files using either 3dsmax or 3dvis, there appears to be graphics glitches in the form of lines in the image that shift as the view. Anyone have any idea what could be causing these? They appear on other computers as well.
Anyway, thanks in advance for all your help
Athlon XP 1700+
