Hi guys,
I built this computer about 6 years ago and it has served me well since then. I'm getting to the point, however, that games are starting to require more than this little guy can handle. I'm wondering if it's possible to upgrade it, or would that be wasting money that could go to a completely new build. Here are the parts:
(These are out of production at this point)
CPU - http://www.newegg.com/Product/Produc...82E16819116238
Mobo - http://www.newegg.com/Product/Produc...82E16813135225
GPU - http://www.newegg.com/Product/Produc...82E16814122245
Ram (Two of these sticks) - http://www.newegg.com/Product/Produc...82E16820121020
PSU - http://www.newegg.com/Product/Produc...82E16817103937
Case - http://www.newegg.com/Product/Produc...82E16811112025
HDD - http://www.newegg.com/Product/Produc...82E16822148100
Main concerns:
As I mentioned above, I do some gaming on this machine. I wouldn't say it's 100% of the purpose, but it's maybe 70%. I'm getting low FPS and a lot of tearing when I try to play some games. I'm also forced to put some games in the "low" category. I'd like to run things a little smoother...
Hand in hand with the above problem however, the motherboard I have in this machine does not support PCI Express 2.0 x16, it only does 1.0.
I'm pretty sure that if I want to replace the video card I have now, I'd need to get a new motherboard. And if I upgrade the motherboard, I may have to get a new CPU, since I'd have to find a 755 socket board that supports whatever the heck the CPU I have above is.
The CPU isn't labeled clearly, so I don't know if it's a Pentium D, or a Dual Core, or a Pentium D Dual Core. I tried looking for a motherboard on newegg that supported a 755 socket CPU, that also has a PCIE 2.0 slot, but wasn't coming up with anything good - mainly because I wasn't sure what to specify with that CPU.
Advice? Worth throwing money into upgrading this machine? Should I salvage some parts and build a new one? Normally I'd just build a new one, but I've been out of the building game for a while, and don't want to spend a lot of money. Would consider it though, if an upgrade is not viable.
Thank you!
Main concerns:
Thank you!
