Upgrade help for a gamer.
zzglenn
Hello All,
I am looking to upgrade my current system, and I am confused on what is the best bang for the buck for my situation. I have around $500 to spend. Most of the parts in my current build I would like to carry over, but I need advice on newer ones.
Current Parts:
HD : Crucial RealSSD C300 128GB, Samsung F1 SpinPoint 750GB, WD HD 1TB
PSU: CORSAIR Enthusiast Series CMPSU-550VX 550W
CASE: NZXT TEMPEST Crafted Series
VC: ATI Powercolor 5850
Media: DVD/CD burner
LCD : SAMSUNG P2770FH ToC Rose Black 27" 1ms
SC: Creative SB X-Fi
OS: Win7 Home
Parts Needed:
MB: Asus?, GB?, Asrock? z68 series or go with P67? I normally always buy Asus, but open to other brands with better peformance, or to save money.
CPU: InIntel Core i5-2500K Sandy Bridge 3.3GHz . I'm pretty sure on that one unless someone objects?
RAM: I would like to OC and have 8GB. Best bang for the buck?
PSU: Will I need a newer one?
Cooler: Something other than stock?
This system will be a family computer so I will be watching videos, doing word, and playing games. In the end though this will be mainly a gaming rig. I would like to OC the sandy bridge processor to squeeze some more life out of it, but it may not be for awhile, and it won't be extream. I am not currently SLI/Crossfire, but maybe in the future if 5850s go down in price.
Any thoughts or help would be greatly appreicated.
Thanks
If you are planning on overclocking your CPU, then you want a 2500K, the ram speed doesn't make a difference on SandyBridge. The "K" series chips have unlocked multipliers.
Personally I would go with a Z68 chipset. And get one with on-board monitor connectors like DVI, HDMI, VGA to turn the machine into an HTPC later on down the road. Some Z68 motherboards don't offer on-board monitor connectors so be careful choosing a Z68 chipset.
For peace of mind I would get an aftermarket HS&F. The mainstream HS&F 2500K combination includes the Cool master Hyper 212 and it's ~ 29$ at Micro Center. BTW, if you have one near by they have a great deal going on for the 2500K = 179$ in-store pickup ONLY.
Hi BTry,
Thanks for the correction. I must have copied in the wrong title.
So memory wise is this the best then for a Z68 board and OCing?
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) $99
Sounds good. I will look at the Z68 boards. Do you recommend air or water for heat now? I don't have a Micro near me 🙁. Any recommendations on boards? I like the idea of having the HDMI out on the board.
Do you recommend air or water for heat now?.
To be safe, I would get a mainstream aftermarket cooler. Most everyone seems to pair the 2500K chip with a Cool Master Hyper 212. This seems to be the best price for performance cooler atm, :thumbsup:
32nm chips seem to run real cool so there is no need to liquid cool unless you plan on breaking overclocking records or going for super high overclocks ~ 5Ghz +
I haven't looked at the latest Sandybridge boards too in-depth. Asus seems to be everyone's favorite. I haven't bought a board by them in 3 yrs due to some neglect on their bios updates on a ROG board I bought by them. But they really seem to be shaping up. Haven't heard anything bad by them in a while AFAIK. Look through the list of Z68 boards at New Egg and see what suits you best.
Cooling: I agree I will go for the Cool Master Hyper 212
Mem: I'm still confused
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) 43.99 x2
or
Z68 Boards: They still range in price quite a bit, and with the new BIOS i'm not sure which is going to be better.
ASUS P8Z68-V PRO LGA 1155 Intel Z68 HDMI SATA $200
but
ASRock Z68 PRO3 LGA 1155 Intel Z68 HDMI SATA $120
and
GIGABYTE GA-Z68X-UD3-B3 LGA 1155 Intel Z68 SATA in the middle for $145
For RAM it is best to stick with anything @ 1.5v or <
And I still like to run ram with lower timings if I have the opportunity. Most people will say its nonsense but to each their own. T
If you do end up going dual GPU down the road, depending on the GPU you might want to get a larger PSU. The best place to read up on PSU reviews is JonnyGuru Pay attention the the regulation, ripple suppression, and efficiency.
As far as motherboard for the 1155 socket, I haven't really looked that deep into them. I know the latest chipset is the Z68 which gives the user the ability to use the onboard GPU from the CPU without a discrete video card & the ability to overclock the CPU.
It's best to read up on it. Read the Anandtech article on SandyBridge Link.
or
You'll definitely want to go with 2x4GB instead of 4x2GB, but you don't need to spend anything near $100. This G.Skill DDR3 1333 8GB for $75 will work fine.
but
and
All H67, P67, and Z68 motherboards perform the same, so it really comes down to features. From what you've described, the ASRock Pro3 should work great for you.
Thanks mfenn.
I guess I am confused. I currently have only ever OC'd my current machine and I had to get faster RAM to handle the FSB increase. If I want to overclock the Intel Core i5-2500K should I not want the fastest DDR 3 the motherboard supports?
As for boards... I have always bought Asus, but don't know much about ASrock. Am I going to get the same quality, or am giving up quality for cheaper material/components. Of course I know Asus ups the price for features that have little or no use.
I know Z68 boards are new so I didn't want to go with a lesser company who doesn't update the bios or have some sort of RMA if something goes bad.
The price however is really nice.
Thanks mfenn.
OCing has changed with SB. The bus is practically locked and you'll be increasing clockspeed through the CPU multiplier instead.
ASRock was originally owned by Asus. ASRock does tend to be a bit cheaper, but I haven't heard anything particularly bad about them (other than lemons or whatnot every brand will throw out there every-so-often).
So I have gathered this so far.
CPU: Intel Core i5-2500K $225
MB: Still debating on the boards ASrock or Asus. Regardless Newegg doesn't have either of them stock at newegg ~$200
Mem: G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) $75
Cooler: Cool Master Hyper 212 $30
If there is any thing else anyone can think of I am missing let me know.
The Pro3 shows as in stock for me. There is really no reason to be spending $200 on a Sandy Bridge mobo, unless you need a very specific feature. As another alternative, the GA-Z68A-D3H is quite good and is the same price ($130) as the Pro3.
