AtenRa
- Feb 2, 2009
- 14,003
- 3,362
- 136
How is an FX-6100 $40 cheaper than an i3 setup?
You don't need a z77 chipset with an i3 because you can't overclock anyway, and an i3 itself is ~$130.
http://www.newegg.com/Product/Produc...82E16819116775
Since you can't overclock anyway you can go with the stock HS+Fan and a smaller PSU, and dump that extra money into a better GPU.
EDIT: I'm not arguing that an i3 is a better CPU than an FX-6xxx all things considered, but that it's not more expensive and that it IS competitive with an overclocked FX-6 in games.
I'm in a similar spot want to build a Guild Wars 2 PC for the other half but money is tight. Can't decide if I should go and 6100 (I live near a microcenter) for about $130 with motherboard or an i3 2100 for apx $170 with motherboard or go for the i5 3450 for about $230 with motherboard.
I commented for the above prices.
Also, If you dont buy a P67/Z68/Z77 motherboard you handicap your upgrading path and you will not be able to fully use a K series CPU later on.
