Hello, I was able to clone the hdd to the Samsung ssd. Now I need help on how to boot from the ssd and assign the hdd as only secondary storage.
Thank you!!
The simplest thing to do (assuming you're in AHCI mode) is to shut down the computer and unhook the SATA data cable (only) from the HDD. Then when you boot, the system will be forced to boot from the SSD.
Once you're happy that everything is correct, shut down the PC, hook the HDD back up. When booting, this time go into your BIOS and make sure the SSD is *first* in the boot order. Save and exit the BIOS. Once Windows boots back up, you can reformat the HDD and use it for storage.
