Hi All,
I just bought BF3 premium and I've found that some of the new maps I'm getting really poor framerates on. I was getting 40+ on some of the core BF3 maps which is good enough for me but 20-25 on the bigger maps which is a slideshow... I found that I can get 30+ by reducing my resolution but I find it much harder to see what's going on that way.
I want to build a really nice gaming rig next year but for now I think I'm limited to a small upgrade. I'm hoping there's something I can do for maybe ~$200 or less that could hold me for a year.
My current specs are:
ASRock 870 EXTREME3 Motherboard
AMD Athlon II X3 450 processor
ASUS EN GTX 460 w/ 768MB GDDR5
G.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 1600
G.SKILL NS 4GB (2 x 2GB) DDR3 1333
Antec VP-450 450W Power Supply
I've tried unlocking the 4th core and overclocking the CPU, both make the system unstable. I used CoreTemp and MSI Afterburner to try to figure out where my bottleneck is and I found that the CPU is running at 95+% utilization and the GPU is running at 60-70% utilization.
So, it looks like my best bet is a CPU upgrade? How much benefit do you think that could provide before my video card bottlenecks me? Will I bet able to get 10+ more fps, or is that too much to hope for?
Newegg has Phenom II X4 965 Black Edition for $99, which seems like it would give a nice boost plus another core plus the ability to overclock.
Also, is it a bad idea to mix in RAM like I have? I have them paired in their proper channels, so I figured it would be fine. But I don't think I considered that they're different speeds. Can the mobo handle that or is my DDR3 1600 being downclocked to 1333? Would it be better to use just 8GB instead of 12?
Thanks!
Thanks!
