SAAA
- May 14, 2014
- 541
- 126
- 116
5GHz Sandy... hmm not bad.
If you are interested in upgrading give a look at the last pages of the Skylake thread and notice what that cpu is doing in some games: at similar clocks it pushes more frames than 6-8 cores older gen processors!
6700K might be a good upgrade then but personally I'd never get less core than I already have (unless the difference is staggering) so holding till Skylake-X 8/10 cores should be a great idea. Overclockability should also go up against Broadwell-E: even more refined process/architecture and no more FIVR.
Kabylake likely is just a minor step so the quad cores will only have clocks as advantage, Skylake had the gains in games this generation, Haswell in compute. Likely Skylake-X has different cores than 6700K, derived from the server variant, and supports newer AVX and possibly larger caches, so it will be even better at compute.
