- Sep 11, 2018
- 2
- 0
- 36
Hello!
So I've been using the Gigabyte Aorus B450 Pro Wifi (Rev 1.0) for a while now coupled with a Ryzen 2400G. I recently bought the Ryzen 3600 but since this motherboard requires a BIOS update I went ahead using my 2400G to update the BIOS from its default version at F2 to the latest F50.
Even after the latest BIOS, I still can't get it to POST. A "No Signal" on my monitor ( via Nvidia 1660ti and even the 2400G's Radeon Graphics).
No clue how to go forward, I followed some threads here on this forum ( Link here) and I quote @VirtualLarry
This page lists F40 as the minimum version to run the Ryzen 5 3600.
Any help would be appreciated.
Thanks!
Yeah. You'll need to flash the BIOS with an older CPU, to BIOS F31 first (bridge), then use the ECU Firmware update, then flash to F40, then F41a. At least, that's what I had to do with mine. (I have a Gigabyte B450 Aorus Pro Wifi ATX, and a Ryzen R5 3600 CPU, although that CPU is currently in an Asus B450-F ROG STRIX ATX board, because my 240mm AIO WC kit was in that case, and I didn't feel like moving it, so I moved the CPU instead.)
Thanks!
