UPDATED:WORKS Home Theater Question: why do I get surround sound DTS, but not normal 5.1 surround sound from DVD player?
GtPrOjEcTX
10,784
First off, here's the equipment I have:
Panasonic SCHT05 Home Theater System
Apex AD-500W DVD player
The DVD player has "Dolby Digital, DTS, PCM out" though a digital coax line. I've plugged the other end of this line into the Panasonic receiver.
On the receiver, when on "DVD" option, I've set it up so that it uses coax for the D-INPUT.
When playing a DVD I press the "AUDIO" button on the dvd remote to switch audio tracks. When set to 5.1 AC-3 I get no sound, but if I have a DVD that uses DTS and has the 5.1 DTS sound track, whenever I switch to that I get sound from all the speakers.
What am I doing wrong? Thanks.
BTW, I just registed at hometheaterforums.com but evidently they have to check your username manually to see if its valid, so I can't post nor search there yet.
UPDATE: I set the audio output to SPDIF/RAW and it works great now. Thanks guys.
Modeps
17,254
44
Isnt AC-3 and DTS two differently encoded streams? I would think that perhaps you shouldnt get sound out of the AC-3 when you're running it through a DTS receivier, try changing your receiver's input mode?
edit: I'm not an audiophile, and I'm not super smrt about this stuff, but just a suggestion :)
spacejamz
10,935
1,592
check your audio options on the dvd player to see what output stream is being sent from the dvd player to the receiver...
Viper GTS
38,107
433
Yup, most likely one of the streams is disabled.
My DVD player came by default with DTS digital out disabled.
Took me an hour to figure it out.
Viper GTS
PanzerIV
6,875
Viper GTS
Agreed. I had the same issue once and played around with the options and got everything working fine.
Kelemvor
16,928
8
My DVD player came with DTS/Dolby Digital disabled for some f'ing retarded reason. Took me like a year to realize is. I was getting 3 fronts and 1 rear (both rears the same) until I got into the DVD player settings and found it was off. THen I went and watched all my movies over again and revelled in the sweet sounds...
waggy
68,143
10
Viper GTS
same.
also my reciver had DTS disabled. also some DVD's are only encoded for one. but might check in the langueges option to see if it has the other.
GtPrOjEcTX
10,784
Viper GTS
this was it. heh before now I didn't even now that the dvd had a setup option.
