SlickSnake
- May 29, 2007
- 5,235
- 2
- 0
Originally posted by: taltos1
Wow. Thank you for all the replies but I am still a bit in the dark. I understand that there are 2 elements at play here: energy savings AND longevity of the electronics.
Energy Savings:
It seems the "Power Strip" method will save some energy, but perhaps not as much as some are touting.
Longevity of Electronics:
Some say the power strip method is good, other say it is bad. Both sides have made what seem to be valid points (IMHO, I am no electronics guru) but I am still not sure what to do...???
I power strip everything. Except lights and appliances. The biggest risk you will have on electronics is line surge, not lack of continuous current. Yes, the alternating of current is hard on electronics that require a steady current, but the line surges will fry just about anything connected that is not protected somehow. Turning it on or off at the strip versus at the device should make no difference, unless you are operating heavy machinery or high voltage electronics. I turn off my reciever (1500 watts) and 3 powered subs (another 1500 watts) using the Monster power strip plus all the attached components and have not had a problem yet. Of course, the volume is turned down when I do it, not cranked full blast. And the system is not actively operating when I do it. So these are things to consider as well.
