I was going to test my mobo and processor to see if it posted. All I installed was mobo, cpu, and vid card. I hooked up the atx power connector to the mobo and then started placing the other led connectors on the board. However, 2 are messing me up. They are the System Power LED lead(pwr.led) and the speaker Led. The reason for this is that the power LED has 3 pin slots and the speaker led has 4. However on the lower right hand corner of the board where these are supposed to go, there are only 2 pins for each? How am I supposed to connect them to 2 pins when they have 3 and 4 slots respectively. However each connector only has 2 wires going to them, but they are split apart by dead slots. So I tried sliding the slot the power wire of each connector went to into the power pins on the mobo and just leaving the ground dangle. However, when I tried to boot nothing happened. I made sure that I turned the power supply on first and I repeatedly pushed the power button on the front of the case. I know that it has to be that danged power.led that is messing things up. Anyone have a solution for me. I would really appreciate it.
Thanks.
Thanks.
