[Updated] Need help checking set theory mathematical notations
Status
Not open for further replies.
MobiusPizza
2,001
I am a beginner in set theory and more importantly the notation conventions. I am trying to describe what I am doing below in mathematical notation:
Given a set A, containing elements which come in non-distinct pairs e.g. {a,a,b,b,c,c,c,c,d,d,.....}
I am to partition A such that
P1...Pn, being subsets of A, contains identical elements. For example, P1 = {a,a}, P2 = {c,c,c,c}, etc.
I can use plain English but it doesn't sound cool :)
Thank you very much
iCyborg
1,388
94
The {list_of_elements} notation is quite standard. The only thing that's not standard is referring to a collection that contains duplicate elements as a set. The word you're looking for is multiset.
MobiusPizza
2,001
Thanks, I found out multiset and classes (collection of sets)
I was able to write the following:
I just need some Mathematics guru to check over the syntax. q and r are defined constants. R^q is the cartesian product of R q times.
I mostly followed the ISO-80000-2 notation convention. I used {{}} to indicate multisets, <> to indicate classes.
Below is still valid:
Except set A is now really multiset S, and P is a class which contains all possible S. The partitions are now Q (= P1, P2 in the old quote), which should contain the largest partition of common elements only. In the quoted example {c,c} is not valid cadidate for Q while {c,c,c,c} is. The union add symbol in the equation is to simulate this partitioning behavior.
Lastly, the elements are acceptable to Q if there a even number of them, except if the elements are numerically equal to r, a predefined constant, then there must be odd number of r's.
It still looks awfully complicated to me, any simplifications?
Thanks again in advance
iCyborg
1,388
94
Your f(Q) doesn't make sense. E.g. if r is not in Q, it's defined as f(Q) = 2n for all n?? It should be some n, though if I understand your intention, you should just use something like
2 | f(Q)+1r(Q), | is fairly standard notation for "divides".
Also, you're using logical conjunction everywhere (the upside-down v), which means that r must be in every S part of P, but you seemed to imply it doesn't have to be?
I don't understand that 2nd conjunction and the union-add symbol...
MobiusPizza
2,001
Thank you very much for the reply, very much appreciated iCyborg
Oh thanks, basically cardinality has to be an odd if r is in Q
At least one r indeed must be in every S, this is one of the criterion for forming S. S is basically one or more Qs joint (union-add) together. Put it another way, Q are partitions of S. Q may be just several r's (odd number of them) or some other number (even number of them). For a given number, say 1.5, Q is made up of the greatest number of 1.5 while still a subset of S, say four 1.5 units: {1.5,1.5,1.5,1.5}=Z are in S. The union-add symbol is there such that subset of Z are not contained in Q, for eample. {1.5, 1.5} can't be Q since {1.5, 1.5} union-add {1.5, 1.5} is Z hence is part of S. Therefore if Q contains 1.5 it must be {1.5,1.5,1.5,1.5} and no less.
An example is easier to understand:
If S = {1,1,2,2,3,3,3,3,4,4,4,4,4,4,r,r,r)
Hence Q = {1,1} ; {2,2} ; {3,3,3,3} ,{4,4,4,4,4,4} ,{r,r,r}
Q cannot take the form {3,3} nor {4,4} nor {4,4,4,4}
It's as simple as that. However this example is top-down, the intention is to say S is unknown and we are building S from Qs which satisfy the criteria set in the set-builder notation. From the all possible combinations of S we build P.
iCyborg
1,388
94
Ok, I think I got it now.
I'm not sure that {{R_q}} notation is proper, at least from wikipedia because that ISO document costs 140CHF :eek:
And it seems more like a multiset of q-tuples of R to me, although q has no meaning at that time, which is a problem on its own.
That 2nd conjunction still confuses me. Basically it reads 'for all Q<S such that (something)'. This doesn't really evaluate to true or false. It should be more like 'for each element there's a Q that contains it and has that condition satisfied'.
I'm not sure about the condition either: say Q={3,3,3,3}. There's no D={{x,x}} such that Q\D=0.
I think it would be easier to use multiplicity function:
http://en.wikipedia.org/wiki/Multiset#Multiplicity_function
You could say that 'for all x elt of S:
a) 2 | 1_S(x) + 1 if x=r (or use doesn't divide symbol)
b) 2 | 1_S(x)
Then you don't need all these Qs and weird contraptions.
Building these Qs in any practical way (whether by hand or programmatically) is pretty trivial anyway.
Status
