- Dec 28, 2000
- 1,345
- 0
- 0
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Mostly Video Playback, Video Editing (Vegas/Premiere), Photoshop, Downloading Files. It won't be a dedicated HTPC but I'd like those entertainment features. I'll need Bluetooth and also wireless networking. No Gaming (maybe in the future).
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Under $1000 excluding monitor. I'll be using a DELL W5001C until I save up for a dedicated 24" monitor (sometime in May)
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
None but I want to stay with ATI Video Cards (46xx/48xx series) as it seems like I might be able to do Audio over HDMI which would be a big plus with my monitor/tv.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I've got an external 750gb Maxtor that I'll be using for backups. Other HDD's I have will be put on sale.
6. IF YOU have searched and/or read similar threads.
Read too many.
7. IF YOU plan on overclocking or run the system at default speeds.
OCing.
8. WHEN do you plan to build it?
ASAP
The last system I built was with an Epox board. I've been using a crappy lappy the last 2 years and need something that won't be laggy. So far I've come up with the following
Pioneer Black 20X DVD+R 8X DVD+RW 12X DVD+R DL 20X DVD-R 6X DVD-RW 16X DVD-ROM 40X CD-R 32X CD-RW 40X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner - OEM - $22.99
Antec P182 Gun Metal Black 0.8mm cold rolled steel ATX Mid Tower Computer Case - Retail - $118.99 (looking for a deal on this)
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply and bought it. $80.74 Shipped - $20 MIR (ALREADY BOUGHT)
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: $74.99 (OS/APPS)
ASUS EAH3450/DI/256M Radeon HD 3450 256MB 64-bit GDDR2 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Low Profile Ready Video Card - Retail $29.99 - $10 Rebate (ALREADY BOUGHT from Newegg)
OCZ OCZ3P1866C9LV6GK 6GB PC3-15000 (DDR3-1866) Triple Channel Memory - Retail - $119.99 - $50 Rebate (ALREADY BOUGHT from ZZF)
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail - $279
ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard - Retail - $269
OR
Foxconn Renaissance LGA 1366 Intel X58 ATX Intel Motherboard - Retail - $249.99 - $50 Rebate
USA
Read too many.
OCing.
ASAP
OR
