- Apr 20, 2008
- 10,065
- 984
- 126
I've seen alot of people get good advice here so tada! Here it goes..
I have a 1994 Subaru Impreza L 1.8L AWD. It has 209K (bought at 203K just 3 1/2 months ago) and has a minor oil leak and a torn CV joint. Those problems I'm not too worried about. What I am worried about is my Knock Sensor.
I entrusted my father to work on my car. About a week ago I was running an errand on my break and as I tried to start my car to go back to work it hesitated really bad. I sat there more a minute trying to get my car to finally turn over and fire up. Well after a minute or two it fired up and I was on my way.
When I got off work the problem persisted and the car wouldn't fire whatsoever. I tried for over a half hour. I called my brother and we put a multimeter to my battery and it only read 5V. I thought i wasn't getting enough spark as my lights dimmed when i tried to fire up. The new batter I bought powered at the correct charge (approx 16V) so that wasn't the problem. We then tested if the spark plugs were getting power during ignition and after a few shocks to my brother we concluded it was.
So then I bought the book to my car and had my father run more testing on it. After about a day of testing he said that the only part that doesn't work properly is my Knock Sensor. He said after testing that it powered 0hms, which it should be at 6-700ohms (IIRC, i'm no expert) and that the part needed to be replaced.
What does this part actually do? And why is it preventing me from starting up?
I use plus grade gasoline and a high quality 10-30w Castrol Synthetic Oil in the engine. IDK if these are factors and I'm not sure if Subaru engines are made for it.
Does anyone have any ideas where to get this part cheap or if it has nothing to do with my problem?
EDIT: Video added. http://www.youtube.com/watch?v=_aCUVaNuYNM
New EDIT: So today I decided to change the oil in the car. The Oil light as well as the engine and the battery light popped up on failed startups. I already bought a new battery, so the oil was next. I was unaware that the oil I used to change the oil a few days prior to all of this mess was some shit chevron 10w-30 oil. I went back to Castol Syntec (10w-30 high performance, $6.49 quart) and my car fires back up again. Although there is a minor hesitation, all seems well. It's been bad without a car!
I'm going to be turning it on each day for the next week before I'll trust it for a trip again.
Would the temporary regular oil cause any long-term problems?
