thecoolnessrune
So me and brother decided to get a new case for our WHS server as our current 6 year old case was getting cramped. We settled on an Antec 900. We have several drives in the server. A 160 and 320GB IDE drive, a 1TB SATA drive, and a 2TB SATA drive. I think the 160GB drive is a WD and all the others are Seagates.
Anyways, we get everything back in and start up WHS and lo and behold its a mess. Our 1TB drive is not showing up and as such the system is crippled. It's not a terrible thing because we have duplication, so we only lost a few trivial files (and easily replaced), however, it does set us up for a catastrophe later on if we don't get another replacement drive in there.
Before we do though, we're trying to figure out what's happened. It seems too convenient that the drive just so happened to fail when we were moving things to a new case.
And here's where things get weirder. When we hook the drive up to our SATA -> USB external case the drive is easily detected and usable. We can see the data and everything.
We thought maybe motherboard issue but we can hook a different drive into the same SATA port and its detected just fine.
We then thought power supply but even with everything but bare essentials disconnected the motherboard still can't find the drive.
So to recap, the drive can be seen on a Windows PC when connected to an external case but can NOT be seen when connected directly to a computer. What on earth is going on here?
Oh, and we used Seatools for Windows on the drive while it was in the external case and it tested just fine.
Later on this afternoon we're going to head to work to the test bed machines to see if any of the BIOS's can detect the drive.
This has us baffled. Any ideas?
EDIT: Also tried SATA cable and power cable going to a known working drive to ensure it wasn't cables. Drive still wasn't detected so I know it isn't a cable issue.
