Originally posted by: M0RPH
Do you have a Microcenter nearby? They have some nice deals on processors, like E7400 for $80. Seems like you were trying to go budget on the CPU, then you jumped up to the E8500 which is pretty pricey.
Yeah that is what I thought too. The only thing he kept was the 1TB HD and PSU. $190 for a 4870, you might as well get the 4890 for $200 after $20 MIR.
Here are a couple things to consider with your build:
* The one big issue I have is the PSU that you selected. It only has about 24A on the combined 12v rails and really isn't a true 500w PSU. The one in the Antec Sonata III case that I linked above has 34A on the combined 12v rails and it's a 500w PSU. Thermaltake does an okay job with it's PSU's, but they seem to overrate them, IMHO.
* The RAM you selected is okay, but there are a couple of things to consider. The RAM runs at CAS5, which means 5-5-5-18 timings. This isn't a bad thing, but when you go to OC your Intel CPU, you can run into OC'ing limits. Especially since the RAM is already at 2.1v's!! This was the other issue I have with them, the 2.1v requirement for the 5-5-5-18 timings. The ones that are a bit more that I linked run at the stock voltage of 1.8v and also run at 4-4-4-12 timings, which will come in handy later when/if you decide to OC your system.
* The mobo you selected is okay, but if your going with an Intel build I'd suggest getting at least a p45 based mobo. There is more OC'ing room and they usually have more options too, for not much difference in price. I've listed a decent p45 based mobo to consider below for $95 shipped!!
GIGABYTE GA-EP45-UD3L LGA 775 Intel P45 ATX Intel Motherboard - Retail
* You didn't list an OS, so do you have one or are you going to need to buy one??
* Which case are you going with on the 2nd build list??
I'm not trying to spoil your day by critiquing your build, I'm just trying to let you know some more information on things to consider before you buy. I just want to make sure you can make an informed decision on your build. I know I have been in your shoes before and have had some help in my buying decisions in the past.
