- Jul 26, 2011
- 8,548
- 2
- 0
This is a very popular card so I figured this would come in handy:
Copy pasted from http://www.evga.com/forums/tm.aspx?m=1703680
EVGA GeForce GTX 670 Firmware Update v80.04.31
Q. What are the changes in this new firmware?
Improved stability
Improved compatibility with DELL XPS 8300 systems
Q. Do I need to reapply this update every time I update a driver or reinstall the O.S.?
A. This update is attached to the card, no matter where it goes. If you update the driver, the EVGA firmware update is still applied.
Q. How can I tell what version I firmware I currently have?
A. There are multiple ways to do this, one way is to right click on desktop and go to NVIDIA control panel. Click on Help, then System Information. Scroll to the bottom of the Details window and it will show your "Video BIOS version". It will be listed as EXAMPLE: 80.04.31.00.72. The numbers in bold identify the version number.
Q. I just bought my card, will it have this updated firmware?
A. Chances are yes, as new firmware is release, new products shipping from EVGA will also have this firmware version applied.
Installation
Download the correct .zip file below for your graphics card below.
Extract the files to a location on disk.
Make sure no programs are running in the background, and double click update.exe.
Press "Y", then ENTER to begin the update.
DO NOT TURN OFF POWER OR RESET DURING THE UPDATE PROCESS!
After update, restart PC.
EVGA GeForce GTX 670 2GB:
v80.04.31 02G-P4-2670-KR - EVGA GeForce GTX 670
v80.04.31 02G-P4-2672-KR - EVGA GeForce GTX 670 SC
v80.04.31 02G-P4-2676-KR - EVGA GeForce GTX 670 FTW LE
v80.04.31 02G-P4-2678-KR - EVGA GeForce GTX 670 FTW
Improved stability
Installation
