Kelemvor
UPDATE:
OK, GOt the pads changed and had to take the top off the reservoir. Fluid came all out everywhere so I'm assuming the oil change place must top off the fluids for me when I go in. One pad was literally gone so there was a ton of extra fluid in there.
So, NEW QUESTION is, when I put everything back together, should I put the cap on, then press the brakes a few times, then release and put the cap back on again to relieve any pressure issues? Or does it not really matter as far as when and how to put the cap back on?
OLD QUESTION:
I'm putting new pads and rotors on my truck but am not (at this time) changing the fluid and such. (I'll do that when I have more time).
WHen I putthe new pads and rotors on, I can't get the pads/caliper on the rotors because they are now too tight. Since I'm not changing the fluid, what can I do?
Can I just take the cap off the brake fluid reservoir and will that relieve the pressure that I can push the piston back in further so I can make them all fit? And then just screw the reservoir cover back on when I'm done?
ANy other ideas?
Thanks.
OLD QUESTION:
ANy other ideas?
Thanks.
