*Update* XP-M 2600 results
AWhackWhiteBoy
1,807
Originally posted by: myocardia
Weasel, how do you know that it's your board holding you back, when you have PC2700 ram in there?? Anyway, yes, 12.5x is the maximum multi, unless you own an NF7-S or an A7N8X-Del.
my lanparty does 15x
BlueWeasel
15,930
454
Originally posted by: Cheetah8799
What temps are you seeing now? And what CPU heatsink/fan you using?
I am running a TT SilentBoost (all copper HS, similar to the SLK series) with a low-RPM, 80mm Panaflo L1A. My idle temps are 37-40C, and the highest max temp. I saw last night was 48C.
magratton
523
So we can all compare:
Abit NF7-S v2.0
AXP2500M @ 2.4Ghz w/1.65MHz (200FSB x 12)
Cooling: ThermalRight SLK947U w/Vantec Tornado 92mm (AS5 as well)
Idle: 40C
Highest Temp Witnessed: 48C
Killrose
6,230
8
Cool, you got some 200MHz FSB action :beer: maybe with a little help you could get 210MHz? :)
If it is'nt memtest stable at 200MHz, you may need a little help anyway's.....
myocardia
9,291
30
Okay, I just rebooted and checked, to make sure, and the 8RDA3+'s also have full 5x-24x multi support for the mobile Bartons. I never even thought to check before now, because I was only interested in somewhere between 11.5 and 12.5, anyway. My board will go as high as 222fsb with this chip, but my ram won't do 222 without going to 3-4-4-11 timings, which is actually slower than what I'm running it at now.
ASK THE COMMUNITY
