UPDATE: Was the Amp! Car Audio Problem... no subwoofer
ChefJoe
2,506
The past few months, I have noticed some really lacking bass in my car stereo... one that I put together when I was still in HS, I've since graduated from college and this car was sitting in the driveway for 4 years... I've even seen condensation on the subwoofer's enclosure, so I'm not suprised that something has gone bad. Anyways, how do I isolate this problem? I did the trick of taking a AAA battery and wire and using it to see if the Vega 12" sub makes any noise (just tapping the circuit closed)... I hear a quick little pop when I do that, so that's good, I think.
The cheap old Jensen 250Watt(max) amp says it's got power ok... I pulled out a standalone HT type CD player and wired the RCAs of that into the amp, played a really bassy track (yes, it's a bridged amp with Low Pass Filter) off that new Eminem CD, nothing.... seems like a bad amp.
I tried plugging in my headphones to the RCA out (well, the exposed end that's in the trunk) of the CD head unit... couldn't hear anything more than a low-noise static (very faint, didn't sound like music at all).... would I be better off getting an adapter from radioshack to see if the head unit is gone too?
I'm trying to figure out what's wrong without going to a car audio place, because I believe they would want to sell me something and I really am not sure it's worth fixing this sub in my old car.
EDIT: I found a connector which changes the rca outputs of the amp (the pass to a second amp) to a stereo connector and was able to hold my headphone connector to it and hear audible/understandable radio signals... meaning that my rca jacks are fine... amp is no longer doing any amping. Since I want something only to power my vega 12" V124 which does 400W nominal (I assume that's RMS) and 800W Max, I'm thinking about one of those sony XPlode XM-2150GSX models which is rated for 380W bridged RMS and 760W peak... seems a good fit and should only run $200.
Viperoni
11,084
Hmmm....
The headphones likely would be very quiet when running from a decks RCA-outs.
The sub should be okay, but it looks like the amp is dead.
ChefJoe
2,506
New testing seems to suggest my amp isn't working. Would I be a horrible person if I got a $200 Sony XPlod to replace this old $100 Jensen?
ChefJoe
2,506
This is horrible, I've been given suggestions rangeing from JBL 600.1 ($201 shippped from ebay) to USX models (of which the USX2150 for $180 shipped or the USX800D for $245 shipped seem appropriate) or even these Cadence models... which is a brand I've got no familiarity with and can't figure out if their wattages are RMS or Peak.
I've got a 2 V. RCA output which works fine... just can't trust the head unit for any bass enhancement.
The wiring is done in 8 gauge with a 40 amp fuse (and than 800D is written as requiring only a 50 amp fuse... I probably could replace the 40 with a 50 if it ever blows (I don't listen to ultra bassy stuff) without any really ill effects).
I have a Vega 12" V124 which is rated for 400W RMS and 800 W peak in a ported 2 cu ft bandpass box.
So, choices are my main difficulty at this point. Any thoughts ATOT?
