[UPDATE] My shoe is going finished
SandEagle
ok so i have an interview coming up and i want to make a good impression. i'm going clothes shopping tonight. my shoe is also going finished. help me pick some nice dress shoes, please. i typically shop at Macy if that helps. i said please, so knock off the horseshit. thanks
i said thanks too. if i pick your shoe, i will add you to my friends list. :awe:
UPDATE: ended up getting these Kenneth Cole shoes. they look like shoes from the future. its like wearing sunglasses on my feet
http://www1.macys.com/shop/product/k...fers?ID=509728
http://www.endless.com/dp/B003UA9E9...e=395033&linkCode=asn&creativeASIN=B003UA9E9A
you're just going to find overpriced garbage at macys*. either spend a decent amount and get something nice from elsewhere, or shop a different cheap place
*my opinion based on spending 2 minutes browing the website
English grammar fail ...
SE ... what are you trying to say? We don't understand jibberish!
Prada are going to fit the narrower foot a little bit better (which is me, so they are my preferred brand). If the OP has a bit wider foot I would recommend something from Ferragamo or even Allen Edmonds.
Ferragamo makes some great casual slip-ons as well for winter. As indestructible as a boot but in loafer form.
http://shop.nordstrom.com/c/salvatore-ferragamo/mens-shoes-oxfords?origin=radio-filter-dropdown
http://shop.nordstrom.com/c/allen-e...alse&lastfilter=searchcategory&sizeFinderId=9
How old are you?
What kind of job?
is your CPU also cold with solution?
did you accidentally solution on your shoes?
is that why your shoe is going finished?
actually, i prefer KC joota or anything similar with the clip on top:
Sorry, but that looks like a clunky piece of shit. If you want to look classy, buy cap-toe lace-up oxford. Skip the jewelry on the shoe unless you're going to wear it in your hair or ears (ie, don't do it), don't wear a loafer to an interview.
Square-toe = lose.
As I said before, captoe oxford lace up. Nothing more, nothing less. Shine it before you go. They won't look out of style in 2 years either.
Square-toe = lose.
http://us.estore.johnlobb.com/oxford/philip-ii.html
http://www.crockettandjones.co.uk/oxfords-drummond.html
http://www.crockettandjones.co.uk/oxfords-hallam.html
