- May 7, 2002
- 2,039
- 0
- 0
Update: Fixed. So what I did is
1. mast clear under 2.1
2. root and unlock
3. install cognition 4.4.1
4. insert T-mo sim card to test, full signal strength, no problem
5. insert AT&T sim card, signal strength fluctuated for two mintutes, then full bars.
6. add an APN, disable the AT&T 310 410 APN.
7. Restart twice, everything is back to normal.
I googled and there seemed to be no definite solution. I wish someone here can help.
Symptom:
Captivate with stock firmware 2.1 (or 2.2), clean reset, no unlock. The AT&T signal strength changed from -50 to no service in a few minutes after powred-on. Checked filght mode is off. The battery level dropped like 1% every five minutes searching the network. Sometimes could make one call then no more signal. Restart the phone, get the signal for one minute, then no service again.
The same sim card is working well on other HTC android phone. The signal is very strong on other phones because there is a cell tower 10 blocks away.
Is it a hardware failure? Any possible settings?
Thanks.
2. root and unlock
Symptom:
Thanks.
