- Oct 14, 2005
- 9,711
- 6
- 76
Originally posted by: MADMAX23
Nice...now you can start tweaking your Ram memory!!!
cmdrdredd: I think you haven't read my short description of my testing methodology!
I did and you don't understand. If Orthos blend fails how the hell do you know what to adjust? YOU DON'T!
If you fail SmallFFT you know your CPU can't do that speed at the voltage so you know what component to adjust. If your memory fails memtest it's obvious that those timings/speeds aren't working.
MadMax23,
Can you list all your settings? No matter what I tried, the Vcore (in bios) must be >1.5375v (~1.496v in window) .. temp pretty high (63-64*C Full load) ... and Orthor (blend) either failed or system restarted.
These are my settings:
[AI] Manual
[CPU Freq] 400 / 401 / 402
[DRAM Freq] 800/802/804
[Spread Spectrum] Disabled
[Vdimm] 1.9/2.0/2.1
[Vcore] 1.475/1.5 / 1.5125/1.525/1.5375/1.55 (passed Orthor for 40minutes)
[Ratio CMOS] 8
[C1E] Disabled
[Vanderpool Tech] Disabled
[Intel speedstep] Disabled
[DRAM timing] 5-5-5-15-6-35
[Static Read Control] Disabled
Everything else = AUTO.
This is my first time playing with oc ....
E6400
Asus P5B Dlx (0711)
2.1GB- OCZ2G8002GK - PC2-6400
Corsair Nautilus 500 WaterCooling (replaced fan stock with SylverStone FM121)
Arctic Silver 5 thermal paste
2 PSUs (temp) - Aspire 500W + PC PW&C 470W (awaiting OCZ GameXtreme 700W)
Chenbro XPIDER Gaming "Bomb" Case
LiteOn 1653S DVDRW + Optorite DD201 DVDRW
Seagate SATA 120GB hdd.
Originally posted by: Madellga
PC Surgeon, my 2 cents if you allow me.
If Orthos is not stable (the blend), then you cannot trust your system 100%.
My E6400 runs 100% at 3.2GHz. I can get it to run also at 3.4, 3.5 or 3.6
At 3.5 and 3.6 I can only run SuperPi, VCore goes high and Coretemp readings above 65C.
At 3.4GHz, I can run Orthos for many hours. The problem: it can fail at 3 hours or 7 hours or 10 hours - everytime it crashes in a different timing.
Well, I thought 10 hours, not bad and should be stable. Well, what happened is that the computer BSOD during a GW mission, which sucks because I lost it all (the instance resets if you get out). Also, if leave the computer doing video compression for a time, you can come back and find Windows BSOD or computer reset.
Technonut is right, running Orthos or Prime and browsing the Internet (I normally read the news) is a good test. An instable setup sometimes stops the Orthos run just because you opened an Explorer session: that's definitely not stable. At this same condition, the computer could run Orthos for hours, but once I touched it it went down.
What MADMAX23 said is absolutely correct, FSB 400 is the sweet spot: tighter timings, low VCore: high performance and quiet system.
I also want more like you, but I decided it is greed- we already went from 2.1 to 3.2, we should be happy for that. Many people don't even reach this result.
A few weeks ago I had an A64X2 that could only o/c 20%.....I decided to quit the hunt for higher clock....timing and money consuming.
And for the higher results, I think very few are really stable. What people normally show is SuperPi runs, which means nothing for 24/7 stability.
I hope you suceed on your quest, but if not - don't worry, be happy man !
3) Let Ram memory out of equation; How? Running a lower divider (if possible, not with the P5B-D for ex.), increasing Ram voltage (2.2v-2.3v), relaxing all timings (5-6-6-18), testing 2 hours with Memtest 86 1.65 specially tests 5 and 6.
Spiking the RAM voltage isn't nessesary if you are relaxing timings and dropping frequency. Some RAM gets way too hot at those voltages too.
So after getting 6+ hours of Orthos blend, what else do I need for stability?
How about 24 hours of Small FFTs?A few good AutoGK encoding sessions will also show any stability weakness that Orthos missed.
I am currently shooting for 3.7GHz... It has taken many hours of testing, but when/if 3.7GHz goes in my sig, you can bet the farm it is rock-solid-stable... NO BSODs, NO Lock-Ups, (no matter which app/game used) NO Sh1t...
I guess that I am the forum stability nazi....![]()
I am like you Technonut, I can't even use my Pc if I'm not 100% sure it is 100% stable.
So don't change, stability addict, you're not alone!!!
MADMAX, see my post in another thread about your wretched chip!! *shakes fist*
Emmm.... firstly, be gentle. Secondly, wash your mouth. Thirdly, wretched chip? you don't know what you are talking about, do you?
I do still recommend you and everybody to stay at 400 FSB x 8 = 3200 Mhz, it's the sweet spot. Low voltage, a good chipset memory strap, nice memory performance then....it's the best option for 24/7 use. However, you (and me too, why the hell not?) can push your system more...memory performance will suffer until you pass 455-460 FSB but that's up to you. In my case, I just want to find my highest CPU stable OC at a Max voltage of 1.5v. What will I do when I find a MAX overall OC with nice performance? Use for benchmarking and ocasionally, for ex, when reencoding a DVD movie with Procoder 2.0...that kind of tasks, but not for 24/7 use, definitively not.
Right now I'm still testing 3.6Ghz at 1.460v (actual Vcore)...if it passes succesfully my tests, I'll go for 3.7Ghz and so on until I hit 1.5v...but that does not mean I will use that config (3.6 or 3.7 Ghz) for 24/7. I'll use it for benchmarking, not for 24/7, is it clear?
Think about the very first parragraph, body...forum users, including me, don't like that kind of guys here...
24 hrs of orthos small FFT's? Holy crap! Not going to happen.
Why not?.... It does not take much effort if your rig is stable...Like this:
3.7GHz 25 Hour Stability Screenie
Now, off to tighten up those pesky RAM timings some....![]()
