Originally posted by: Basilisk
You're breaking my heart, RobsTV!
Can you post a link to instructions for testing one's unit? Sounds like a necessary first step when mine arrives. [I Googled for such a test, but didn't hit any mention of the problem.]
If you do not have a good charger now, even the poor units will be decent. Just don't expect the end all or greatest flawless charger. You could always exchange if it does not work as well as you desire. I would still get one, even if just for the "cool toy" factor.
Huge thread from December '05 through May '06 at Fatwallet that has links to tests, as well as posts from others that have exact same results of uneven charging slots. In that thread, posts from April mention v33, so it's at least that old.
my tests were simple.
Numbered batteries 1 through 4.
Ran the discharge/refresh at different rates to see how much power the "new" batteries had left.
Recorded results. Used batteries in digital camera.
Repeated discharge/refresh using exact same slots, to confirm first results, which was close enough.
Rotated batteries one slot, discharge/refresh.
Repeat above for a couple weeks.
Varied charge rate to see if it created a sweet spot.
Tested simply charge and discharge same way.
Frowned at results that showed two of the chargers have slots that will not properly charge.
20% difference in slots with larger capacity batteries.
(for example, the same 2400mAh may show actual 2000mAh when full in 2 slots, 2100mAh in 3rd slot, and 1600mAh in 4th slot.)
I don't like sticking in 4 batteries and seeing those results in the display.
The chargers actually work best for me with older lower power batteries, such as 1600mAh.
Many of my newer 2000, 2200 and 2400's rarely hit 2000mAh, and some only hit 1200mAh.
Problem is, my camera's choke with batteries less than 2200mAh.
The chargers did let me throw out several questionable batteries.
