I posted this because of the people showing interest in multi-size chargers but my vote for a battery charger went with the LaCross found in another thread (
http://forums.anandtech.com/messageview...atid=40&threadid=1766683&enterthread=y )
The Lacross takes good care of each and every cell(slow charge) you put in it unless you decide to push the charge current(fast charge) to shorten charge time if you need the thing in a hurry. That makes this a multi-use charger and a good reason to buy it. You won't have to buy more than one.
It looks at each cell and gives you a clue as to what it's capacity might be so if you have more than a pair of them, you can kind of match them up when you put them in whatever you use them in.
I think the worst thing you can do to a cell is put it in service and in series with another cell with more charge in it so one cell in the circuit runs out of current to push and suddenly is subject to reverse voltage across it's terminals. Now you have reverse current through the cell and a cell that may have been perfiectly good but just a little less capacity, now becomes a damaged cell with lots less capacity or a non-functioning cell.
That's one big reason I like that Lacross charger.
I like that it comes with the adapters to make AA cells fit in places where C or D cells are supposed to go. If your going to have NiMH cells, you may as well use them and use them often. Leave them just sitting around and they're not doing anything for you and they just lose their charge over a month or so and you have to recharge them to use them anyway.
If you think about how much money you will save using rechargables, that charger isn't really espensive.
If you can afford to buy regular batteries or whatever the situation so money isn't an issue, buy it anyway and try to send a little less trash to the landfill.
Oh...if you want your cells to last as long as possible, if you use more than one in a device, don't run them till the device simply stops. Pull them out when you see the performance fading. If multiple cells are used as a battery and the battery goes dead, it's almost always the case that the cell with the least capacity or charge in it on that particular cycle is going to take a beating.
Some people say to run the battery all the way down to reduce memory problems. If you're using NiCads, that may be a problem but that's better handled by a good charger that can safely discharge previous to a charge.
