Question Unwise to reuse a mobo from a system where the CPU died?
screwd01
311
I built a system with a 1700x a few years back and it was solid, on 24/7, until last month. I suspect a lightning storm could have killed it. I was away at work and I couldn't boot to bios when I came home.
(RGB) RAM, CPU fans, case fans, GPU power light and fans would spool or light up for a second then the system would shut down after pushing the power button.
I've confirmed the GPU and PSU are fine as I put them in an old system. The CPU was definitely toast as I tried it on a friend's motherboard and it wouldn't get to BIOS either.
Would it be okay to reuse the motherboard?
damian101
291
107
86
I would be really surprised if the motherboard still worked, assuming that the CPU was killed by overvoltage from the power supply.
Reactions: VirtualLarry
damian101
291
107
86
I actually wouldn't expect a CPU to die from being run in a dead motherboard. But I'm no expert, so...
screwd01
311
Okay, thanks for the answers. I'lll grab a new board.
Whenever I can find an old Ryzen for cheap I'lll test it out.
Shmee
8,226
3,131
Hard to say, though if you have any issues probably best to RMA if under warranty.
