imported_Davo
I'm considering some budget PCs from HP and I'm not sure which would fit me better so I thought I'd ask the experts for some help.
Here are the main specs:
#1 - $1000
Athlon 64 X2 4400+ AM2 Socket
GeForce 6150 LE Chipset
Asus A8M2N-LA Board
2GB DDR2 (4 GB Max)
320 GB SATA 3G
or
#2 - $1230
Core 2 Duo E6400 775 Socket
Pentium 965 Chipset
Asus P5BW-LA Board
2 GB DDR 2 (8 GB Max)
500 GB SATA 3G
I don't do gaming but I do A LOT of multitasking. I usually check Outlook periodically while I have use Excel and several IE windows while MusicMatch, uTorrent, Trillian, Windows Update and Weather.com Desktop Alert running in the background. Whenever stuff finishes on uTorrent, I edit it in VirtualDub and then want to burn it to DVD using Nero right away.
Based on my usage, what would you suggest for me? The prices are similar so cost isn't a factor but as always, value is a plus.
Thanks in advance for your advice experts 🙂
#1 - $1000
Asus A8M2N-LA Board
2GB DDR2 (4 GB Max)
320 GB SATA 3G
or
#2 - $1230
Pentium 965 Chipset
Asus P5BW-LA Board
500 GB SATA 3G
