Unstable Wifi signal
Mdq8
Hi ..
I got my new router Linksys08847 EA6900, why do my wifi signal isn't stable from time to time,is it normal !!
i didn't face this problem with my older linksys router .
Thanks ...
Hi ..
Thanks ...
Keep the router in the most central spot in the home and away from anything that might block its signal.
Reduce the number of wireless clients. The more devices are sharing the wireless network, the less bandwidth is available for each device to use.
Change some settings on the router. If the issue still persists then you could try changing some wireless settings on the router. You will have to log into the router’s management page. How to do that you can see here in details http://192-168-1-1.one/
One thing to try is to change to a different wireless channel. Under the wireless settings it is also important to check the Country/Region. If it is set to a different location from you, then you may come across similar issues with the wireless disconnection.
Please click on Wireless Settings below the setup menu. Change the Channel (channels 1, 6 and 11 are generally best, but any channel can be used). Also, change the channel width to 20MHz which will provide you a more stable and less crowded wireless environment.
Click Save, reboot the router, and test for improvement in performance.
WiFi signal is affected by a lot of things, like crowded WiFi environment or any object in between the adapter and the WiFi router.
A few days ago I was repairing a PC. the USB WiFi speed is hovering around 1Mbps- 5Mbps when I placed it under a desk. After I put the PC on the desk, the speed jumps to 150Mbps.
