i just added a 700e with Alpha PEP66 (without FAn) to my system as well as 128 MB Tiny BGA RAM. i am NOT OVERCLOCKING the cpu or the RAM
SANDRA says that cpu temp is around 50-53 C or 122-125F.while MBM5 (motherboard Monitor) and bios hardware monitor show cpu temp of about 33C. Phyisically i can touch the HS with out burning my hand or even feeling too uncomfortible. so may be sandra is wrong? is the temp too hot?
Also my system is crashing allover the place. i cant play more than 5 min of Counterstrike before i am dumped to Desktop (no error shows). or i get continuous errors in internet explorer as shown in one of the subsequent posts by me in this thread.
can any one help me?
i have adjusted Bios settings for RAM to lowest possible (CAS3, 100MHz, Normal DRAM timing) to improve stability, No Luck.
Akaz
Akaz
