Unscrewing a stuck bolt? Need help ASAP, any ideas?
Argo
2 out of 4 bolts holdining the license plate on my car are stuck. And I mean stuck. I've aplied immense amount of force and they still won't buldge. Actually, I'm afraid I damaged the heads of the bolts with my efforts. Is there anything that can be done (save for taking the car to a shop) to unscrew the screws?
I've thought about heating up the bolts, but I can't figure out a way to do that without damaging the car.
drill + reverse thread bit. you drill a hole into the center of the screw head and use a reverse thread bit to remove it.
Bots. From the two that I was able to remove it looks like some dirt got inside, acting like adhesive.
unless you can grab the heads with vice-grips and turn them, then you will need to refer to my first reply. drill and tap (using reverse thread bit)
1 - WD40
if that doesn't work
2 - Wrench with long handle, then fit a long legth of pipe over the end of the handle to extend the handle even longer to give you more leverage.
3 - drill it out
WD40 and then tap it with a small hammer, lots of times the vibrations can loosen the seal, kinda like when you hit a pickle jar lid on something to loosen it.
Originally posted by: OdiN
1 - WD40
3 - drill it out
#2 will surely shear the heads off these small bolts.
Usually these have nylon inserts to screw into, I've never actually seen bolts used, but screws.
1 - WD40
3 - drill it out
Makes it easier to drill out.
