Unreal Tourn. & 3d sound echoing...
Charon8
11
Hi!
I have a problem with Unreal Tournament. If I enable 3D Sound, the sound effects where correctly positioned but endless (or so) echoing... I had a Live! sound card, GeForce 2 MX, & using D3D. I remeber having had that problem some patches ago, or with the UT demo. I patched to the latest version, but the echoing remain.
Any idea?
Thx!
JayPatel
4,488
u might got some kind of eax effect on. check your liveware if u have that installed. also check your advanced sound settings under UT
