Unpowered USB Hubs
desura
4,627
129
101
What are the limitations for these things? Basically they'd be fine for like Mouse/kb/flash drive, but for like recharging the ipod just stick with a computer usb port?
corkyg
Elite Member | Peripherals
27,370
240
I can see no sound reason for un unpowered hub. All USB ports disseminate power. When additional ports are required over and above those on the mobo or chassis (laptop,) a powered hub is usually needed for reliability and to take some of the load off of the built-in ones. Hub ports are normally used only when on-board USB ports are all used.
styrafoam
2,684
They are so hit and miss I don't even consider them usable for the most part. Self powered things like printers and scanners will usually work, but after that it's a guessing game.
Cerb
17,484
33
86
Yes. I use unpowered hubs regularly, but never for anything like charging, or for anything that can be performing a lot of data transferring. I treat the hubs as a way to keep the main USBs free for those devices, like my phone, and external HDDs (modern PC problem: I only use one internal slot, but often need a USB hub, even with 12 exposed USB ports!). FI, my mouse, AIO printer, and joystick all share an unpowered hub, while everything else gets a direct port.
cubby1223
13,518
42
86
It's funny when someone buys an unpowered usb hub to connect their new external hard drive which requires two usb connections to supply power.
lagokc
808
I really wish they had anticipated power requirements when they made the USB standard and made 5A standard across all non-mobile devices :/
Puffnstuff
16,187
4,871
Unpowered puts additional strain on the host mb port and isn't worth it. For a little bit more money you can have a powered port that will not draw from the mb plus can be used for things like recharging or powering peripherals.
Throckmorton
16,829
I haven't seen a drive with 2 USB plugs in many years.
BTW what about USB 3.0? It provides 5amps which should be enough to power several hard drives on an unpowered hub right?
BrightCandle
4,762
One of the main points of an external hub is that you get to have a higher power output for better device charging. Unpowered hubs can be useful for basic peripherals on a port limited laptop but otherwise I don't see much use for them.
bruceb
8,874
111
Only time an unpowered USB Hub is good, is if you are using it with a laptop running on battery and all you are connecting are things like a mouse or flash drive. For anything else, buy a powered USB Hub .. Belkin makes excellent ones and they are not very costly. They come in many sizes, as regards physical size and number of ports on them.
mdbusa
49
So can I assume that the poor reception Im getting from my logitech wireless headphones is beacause I have the receiver connected to an unpowered 3.0 usb hub?
BrightCandle
4,762
I don't get good quality power output from a powered USB hub. Its better than direct from the computer but not by much. They all produce noise in a USB charged AMP I have which is a Fiio E6.
